1 - 14 of 14 Posts
'08 Silver TBSS
I swapped out the Bose speakers for JL Audio C5 components and mounted the tweeters next to the 6.5" speaker in the door. Now theres a gap between the 2 speakers, I feel air blowing on my leg and road noise has increased. Does anyone make mounting plates? Or what's the easiest way to make my own?
2006 white 2wd
You could use 1/4" wood. That is easy to do and I would also seal the other holes in the door skin maybe with a sheet of Dynamat?
stupid white guy
Make your own baffles shaped just like the plastic Bose plates. Make sure to protect them from water by spraying with bedliner stuff or at very least paint them.
On my Impala I used this template
http://www.impalassforum.com/tech/audio/door_speakers/door_template.htm
It would be a good base to start with, haven't had the doors apart myself in the TB but it worked excellent, get some 1/4" wood for it. Not sure if anybody makes a speaker pod for the TB, I later switched to a pod that mounted on the outside of the panel.
'08 Silver TBSS
Is plexi glass easy to cut with a dremel? I just want to make thin adapters. 1/4" wood might be too thick.
stupid white guy
Cut plexi with jigsaw with fine blade on it. And when drilling holes, do not put pressure. Let the bit cut, don't try an push it.
tbss. duh.
the best thing to do is remove the stock speaker mounts and use two pieces of 3/4" mdf stacked. cut one to match the bottom of the oem mounts, and one to the top, and glue them together. plastic / plexi / whatever is to flimsy, the mdf helps deaden vibration
I used the original bose speaker (the adapter) as a template and made my own out of .75" wood. Then made another ring for the speaker to sit on, if that makes sense...
I'll try to find a better pic...
Here is what I did for my old TB.
TrailblazerSS (Soon)
easiest way is to trace the stock one, use 3/4" mdf and paint it black. use rubberized undercoating or something.
Honestly 1/4" would be fine I did it before never had an issue and sounded great, but whatevers the thickest you could use would obviously be better, I'd use whatever ply you have lying around or buy a 2x4' piece and you'll have plenty of material if you screw up. The less plastic you have in the door the better.
'08 Silver TBSS
I've got a large sheet of 1/2" mdf sitting around that I'll use. What's the maximum thickness of wood before it contacts the door panel? I guess 2 pieces of 3/4" wood is the max? Would pieces of dynamat on the back of the wood and paint be good enough moisture barrier? I was hoping to not have to buy any undercarriage coating if I didn't have to.
'08 Silver TBSS
Discussion Starter · #13 ·
Thanks for posting pics. That helps get some sense of how it should look.
1 - 14 of 14 Posts
