1 - 5 of 5 Posts
Can someone please provide a list of torques for the following, or point me to someplace where I can find them?
15 mm top nut
18 mm top nuts
18 mm bottom nut
24 mm bottom nut
TYVM!
'08 Silver TBSS
15 mm top nut
18 mm top nuts
18 mm bottom nut
24 mm bottom nut
TYVM!
I'm going by memory, they should be as follows:
15 mm top nut (spring bolt to clap strut and top cap together?) = I can't remember exactly but it wasn't much, like 24 ft lb
18 mm top nuts (upper strut bolts to strut pocket?)= 32 ft lb
18 mm bottom nut (you mean pinch bolt on shock yolk?) = 56 ft lb
24 mm bottom nut = 82 ft lb
The 15mm bolt is the only one I'm not 100% on, the rest I'm 99% sure on. :)
'08 Silver TBSS
I was "pretty" close. :yay2:
1 - 5 of 5 Posts
