Easy, remove the antenna first then, pull the passenger side cowl trim loose by popping out a few plastic push pins, unbolt the antenna base from the fender, put the antenna back on the base, wrap some tape or foam around the antenna mast rotate the base and slide the antenna under the edge of the trim between the windshield and wiper arm.
It completely disapears and the radio still works.
:coolthumb:
:coolthumb:
