1 - 8 of 8 Posts
So my fog lights stopped working last week. I figured some water had gotten in with all the rain. Finally had a chance to take a look today and that doesn't seem to be the case. I replaced the hid's back to stock and still nothing! Anyone know what this could be?
2006 white 2wd
I suggest getting a 30/40 amp SPST relay and wire the fog lights to the battery. Use the positive wire from the factory fog light wire harness as you 'trigger' wire for the relay. Ground both relay and fog lights to battery.
2006 white 2wd
They've been on for 4-5k. Fuse was #11 15amp. Just pulled and can see its blown. Just figured if it was blowing the fuse it wants too much power. So I'd need one of these. http://www.ddmtuning.com/Products/HID-Kit-Wiring-Harness
That would work or get some 16 ga wire, 30 amp fuse with fuse holder, and a 30/40 Amp SPST relay from radio shack and wire it your self. Either way you go, I highly suggest wiring all ground wires to the battery.
1 - 8 of 8 Posts
