1 - 11 of 11 Posts
Ok well I just pulled my motor due to the typical tbss bearing issues. Thankfully we caught it early before my crank and block turned to scrap. Although I just pulled my cam and litters and found one lifter with a flat roller and no needle bearings and a flat lobe on the cam. I was already wanting to step my cam up already I guess now is as good a time as any. I was wanting to get some input from you guys to see what cam works and what doesn't. The cam I was running was 222/230 dur. 597/600 lift 113+2. And im running patriot heads, .040" thick head gasket, headers, kooks converters , 3200 yank(soon to be 3800), ported intake and throttle body, fwi, efans, thermostat, custom tune, pulleys, and built tranny. I know about the search function but I'd like to get opinions. I don't wanna go too radical because my pistons arent fly cut and this is the wifes daily driver but I want it to perform and hit better then what I got now. Help me out
08 Black Granite
Sorry to hear, glad you found it in time.
What size heads are you running now?
They're the patriot 243 heads with stock size valves and 64cc combustion chambers
I just had my motor done and I went with a comp cam XFI XE-R 232/234 595/598 112 lsa works awesome and nice sound. I have a sound clip in the video thread of my new 402.
Damn that sounds nice! I guess I need to pick up an off-road y pipe too. I'm curious how much better your cam performs over mine with the duration being bigger and a lower lsa
Did you have any piston to valve clearance issues? Or do u have valve reliefs in your pistons already?
No clearance issues at all but mind you my whole motor was completely rebuilt balanced & blue printed, I only reused the block.
Yea I hear ya. If it comes down to it ill just have my pistons cut. Its nothing new to me. I always seem to have to get additional machine work done when trying new combos on my race motors.
Discussion Starter · #10 ·
Sounds to me like the lifter killed the motor by sending material through it and trashing bearings.
Just my thoughts.
Yea its hard to say what caused what. So I just figured I'd step up the oil pump, rod bolts, bearings and replace all the lifters. I wish I had the extra cash so I could buy a rear sump oil pan. Freaking expensive.
07 TBSS AWD
I wouldn't just go bigger with the cam, not worth ~5hp to lose driveability.
I'd save for a nice set of TrickFlows and a matched cam if you're not happy with your current setup. Could also change the crank so you'll have a 402ci shotblock while you have yours apart.
1 - 11 of 11 Posts
