1 - 5 of 5 Posts
2007 Trailblazer SS
i heard that you can still use the factory xm antenna when you switch to aftermarket xm radio. what do i need to do and is there an adapter to do this?
which after maket unit are you going to use?
I used the pioneer GEX-P920XM no adapter no problems.
Just have to remove the plastic piece on the connector, came off easy with a small flathead to undo the latch.
2007 Trailblazer SS
im going with a jvc adapter xm module. so you are saying remove the plastic piece on the factory connector and plug right in?
2007 Trailblazer SS
also i havent removed the factory radio yet where does the factory xm antenna located does it plug directly into the factory radio or is it behind the dash somewhere.
1 - 5 of 5 Posts
