1 - 2 of 2 Posts
Took the tbss on the freeway for the first time in a while and when I wanted to accelerate it would feel like i was pushing on the brake cause it would slow down anytime I would press the gas. Anybody know what it could be ? Also traction control light came on during this time… thanks In advance
06'TrailblazerSS, 07'Z06,71'Stingray
:) Process of elimination. 1) If you manually turn off the traction control button on the shifter, does it still hesitate? If yes. 2) Check sensors on wheel hubs. Are they corroded? They may need replacement. 3) Next you didn't say if happens going only straight. If it occurs when turning check steering sensor. 4) Any codes. If a code could be any number of things. Its the joy of owning a 12 to 15 year old vehicle. Good luck
1 - 2 of 2 Posts
