41 - 45 of 45 Posts
'08 TrailblazerSS
No problem
Super Moderator
So I ordered a used fuse box off of eBay. I decided to take it apart before installing. Turns out it had a broke trace in it. Solder it and the car runs perfect again. Took apart the original fuse box and it also had a break in the exact same spot. Thank you for the help.
Good find, post pics if you can to help us find the bad spots..
'07 3SS 2WD
Mine broke in the same spot. But, it cracked at both bends and the short section fell out. I replaced the whole trace with solid wire from Home depot. I had to buy 200' of it. If anybody runs into this let me know. I'll send ya some wire...
I rerouted it to remove that little jog too.
Rectangle Wood Door Font Pattern
Font Wood Rectangle Pattern Metal
41 - 45 of 45 Posts
