1 - 4 of 4 Posts
2006 TBSS 3SS
Hello all,
Converted to all LED bulbs in the tail lights and head lights. Installed a LM487. It corrected the hyper flash but when I turn on the parking lamps the LM 487 just stops. Hazards or left/right signal won't flash either. Soon as I turn off the parking lamps it continues to flash again. I removed bulbs in pairs at a time to see if it was the LEDs. That wasn't it. I have pulled every fuse and checked every micro relay. Swapped around and even replaced some.
I also have an issue with my rear trailer harness. I get nothing at the plug. Completely dead. I connected the red wire at the fuse block under the hood. New 30 amp fuse. I think the ground is near the drivers rear tire on the frame. I was going to check for rust at the bolt.
What am I missing?
Thanks.
2006 TBSS 3SS
07 TrailblazerSS Imp
Did you put in SRCK bulbs when you switched over to Led? The rear is a different polarity set up compared to normal 3157 bulbs. Its like you would rotate the clocking of the 4 contacts. Regular 3157 has one pos and one neg per side. CK is both pos on one side opposite of both neg. Check your tail fuses
2006 TBSS 3SS
These are the bulbs I have installed. I didn't know about the wiring. I checked my fuses and they are all good. I can re clock the wiring. Thanks for this tip!!!!
2006 TBSS 3SS
So I figured it out. I replaced the LM487 to a LM486. I removed the 194 bulbs from the head lights. Once I install a regular bulb or LED bulb my hazards or signals won't work. They stay solid. Everything else is LED except the small 194 bulbs on the outside of the head lamp. I think its because the 194 bulbs alternate with the bottom larger bulb. The 194 LED I was using were SRCK. Fuses are good. I still can't get my tailer harness figured out. Everything is working with the 194 bulbs out.
1 - 4 of 4 Posts
