Im guessing im one of the only few using it...anyone else???
Steve
Steve
I just ordered it ..I'll be using it on my 408 turbo tbss..:biggrin2:If you need help let me knowIm guessing im one of the only few using it...anyone else???
Steve
Which I will definitely take advantage of...but you are going to need to help me in understanding the HP tables and I find the values are quite different on a lot of the tables, but most of it translates over fairly well...VE tables are very different...but still translatable...I can send a base tune for the 112 to get you started but it is in HP Tuner Format.
I need to make a quick change to the PID Selection File and my custom dashboard early this week, then I will be happy to send it to you...Im running the V2 and would like some help on the PID selection. I changed out the cam along with a few other things. Another thing, are yall using the default LS2 DASH or a custom one? Both would help...
If I can get the correct PID's, I would like to post my EFI log in the next couple of hours and get some positive feedback on what needs dialing in.
PS- Can we post our PCM/TCM tunes in this section as well?
I am going to put the heated O2 sensors on the PIDs so you can track AFR more accurately if you don't have a wideband, but the dashboard will still use the Commanded AFR for its gauge. You will like the dashboard...everyone I've sent it to thinks it rocks for logging!
We should talk to Mike and Tony about that!Sweet, thats what im talkin about. I would like to post my most recent tune, but we cant because its a .tun file.
If you can save it as a .bin file he can open it up with efi liveI can send a base tune for the 112 to get you started but it is in HP Tuner Format.
Is this a different way of writing the file or is it just an extension rename?If you can save it as a .bin file he can open it up with efi live
