1 - 14 of 14 Posts
Where is everyone buying their fans from? And who do you recommend for the wire harness and tune?
Thanks
The one and only JJ
I think your going to get diff responses from this. I personally bought mine from EBAY (GTO EFANS). You can check with Tunetime Performance though as i think their doing a plug n play kit for the ls fans.
Who is selling single fan kits vs dual fan kits? Which type of kit seems to do the best job cooling?
2wd Turbo
:2cents:I like the duel set up due to mine is a DD. If one shits the bed you still have something moving air!
06' TBSS 2WD
I have the PCM4Less harness and brackets, and I bought my fans off LS1tech for $75. :)
How loud is the dual set-up? Can you hear it inside the truck at a stop, when your moving?
06' TBSS 2WD
It's fairly loud outside the truck, but once you get going, you don't hear it at all. That goes for both inside and outside the truck.
Discussion Starter #12
Fastfamilyman, I sent you a PM with some detailed questions.
Thanks
Discussion Starter #13
ShreveportSS, where you located? I live in Shreveport as well off Flourney Lucas.
1 - 14 of 14 Posts
