1 - 2 of 2 Posts
So My efans stopped working again, last time it was the relays, ihave the 2kit relat with spal fans & i had them hooked to a switch to turn off/on efans manualy, because my efans stopped working all of a sudden & i had it tuned to turn on efans but since that stopped working i bought a switch from pcm, but now they stopped turning on, when i click the switch button all i hear are the relays clicking, the fuses are good but idk if its the relays or fan motor has gone bad or what, can someone help?
Relays are cheap to buy and swap out... you can also use a multimeter to test connectivity and use jumpers to manually trigger the relay and figure out why the circuit isnt firing properly
1 - 2 of 2 Posts
