1 - 12 of 12 Posts
· Registered
Installed my efans today, but I have a problem. My CEL is on and the gear indicator is stuck on 1. Put the truck into D and tried going forward, but it just doesn't rev at all. My friend's EFILive won't read the CEL code either. Any idea where I fucked up?
Is your computer tuned for Efans? If it isn't then it might be in limp mode because it isn't sensing a cooling fan.
I dont know what tables Vector is using to control the fans. I have messed with the fan setting on numerous vehicles for over 2 years. I use a set of values in the stock tables to activate and control the fans just like the factory intended. I dont know what could be causing the Limp mode unless the fans are not working at all.
1 - 12 of 12 Posts
