1 - 19 of 19 Posts
Hey Guys,
My name is Mani
I'm from germany
I'm searching for a complete wiring schematic for a 2008 TBSS
I want to do a LS2 swap at my 1965 chevy c10
Can someone help me with the schematics?
Thanks
99952
Nice truck. Welcome. I’m sure someone will chime in with the info your looking for.
2008 TBSS Super Charged
Give me a few hours when i get home, and i will jump on gm si and give you what ever schematics you want. Unless someone beats me to it :)
99980
Connector Part Information
  • OEM: 13587097 (LL8)/13574282 (LH6/LS2)
  • Service: 88988373
  • Description: 56-Way F 0.64 Series Sealed (BU)
Terminal Part Information
  • Pins: 1, 2, 4, 9, 12, 13, 16, 18, 20–22, 25, 30–37, 39–40, 44, 46–49, 53, 55, 56
  • Terminal/Tray: 33467-0003/23
  • Core/Insulation Crimp: H/H
  • Release Tool/Test Probe: J-38125-213/J-35616-64B (L-BU)
  • Pins: 7, 19, 51
  • Terminal/Tray: 33467-0005/23
  • Core/Insulation Crimp: J/J
Engine Control Module (ECM) X1
Pin​
Wire​
Circuit​
Function​
1​
0.35 PU​
806​
Crank Voltage​
2​
0.35 PU​
420​
TCC Brake Switch/Cruise Control Release Signal​
3​
Not Available​
4​
0.35 GY/BK​
1694​
4WD Low Signal (NP8)​
5–6​
Not Available​
7​
0.35 L-BU​
1320​
CHMSL Control (K34)​
8​
Not Available​
9​
0.35 BK​
2759​
Low Reference​
10–11​
Not Available​
12​
0.35 BN/WH​
419​
MIL Control​
13​
0.35 D-GN/WH​
465​
Fuel Pump Relay Control​
14​
Not Available​
15​
Not Used (LL8)​
Not Available (LH6/LS2)​
16​
0.35 D-GN​
1049​
Class 2 Serial Data​
17​
Not Available​
18​
0.35 PK​
1020​
Ignition Voltage​
19​
0.35 PK​
439​
Ignition Voltage​
20​
0.35 OG​
240​
Battery Positive Voltage​
21​
0.35 GY/BK​
87​
Cruise Control Resume/Accel Switch Signal (K34)​
22​
0.35 D-BU​
84​
Cruise Control Set/Coast Switch Signal (K34)​
23​
Not Available​
24​
Not Used (LL8)​
25​
0.35 WH​
121​
Engine Speed Signal​
26–29​
Not Available​
30​
0.35 GY​
397​
Cruise Control On Switch Signal (K34)​
31​
Not Available (LL8)​
0.35 BK​
452​
Low Reference (LH6/LS2)​
32​
0.35 GY​
416​
5-Volt Reference (LH6/LS2)​
33​
0.35 WH/BK​
1164​
5-Volt Reference​
34​
0.35 GY​
2709​
5-Volt Reference​
35​
0.35 TN​
1274​
5-Volt Reference​
36​
0.35 BN​
1271​
Low Reference​
37​
0.35 PU​
1272​
Low Reference​
38​
Not Available​
39​
0.35 D-GN/WH​
817​
Vehicle Speed Signal​
40​
0.35 YE​
5991​
Powertrain Relay Coil Control​
41–43​
Not Available​
44​
0.35 PU​
1589​
Fuel Level Sensor Signal​
45​
Not Available​
46​
0.35 D-BU​
1809​
Brake Booster Vacuum Sensor (LH6/LS2)​
47​
0.35 D-BU​
1161​
APP Sensor 1 Signal​
48​
0.35 D-GN​
890​
Fuel Tank Pressure Sensor​
49​
0.35 L-BU​
1162​
App Sensor 2 Signal​
50​
Not Available​
51​
0.5 PK/BK​
429​
Air Injection Reaction Solenoid Relay Coil Control (LL8)​
52​
Not Available​
53​
0.35 D-GN/WH​
459​
A/C Compressor Clutch Relay Control​
54​
Not Available​
55​
0.35 WH​
1310​
EVAP Canister Vent Solenoid Control​
56​
0.35 YE/BK​
625​
Starter Enable Relay Control​
99981
  • OEM: 13606070 (LL8)/13574286 (LH6/LS2)
  • Service: 88988931
  • Description: 73-Way F 0.64 2.8 Series Sealed (BK)
  • Pins: 2–5, 11–13, 16, 18, 19, 32, 35, 42, 48, 49, 52, 55, 67–69, 70–72
  • Pins: 27, 43 (LL8)
  • Pins: 1, 17, 33, 34, 53, 54, 62 (LH6/LS2)
  • Terminal/Tray: 33467-005/23
  • Release Tool/Test Probe: J-38125-213/J-35616–64B (L-BU)
  • Pins: 6–9, 14, 23, 24, 29, 39, 40, 44, 46, 59, 60, 63, 64, 66
  • Pins: 1, 17, 33, 34, 53, 54, 62 (LL8)
  • Pins: 27, 43 (LH6/LS2)
  • Pin: 73 (LL8)
  • Terminal/Tray: 4-964286-1/16
  • Core/Insulation Crimp: E/1
  • Release Tool/Test Probe: J-38125-36/J-35616-35 (VT)
  • Pin: 73 (LH6/LS2)
  • Terminal/Tray: 7116-4152-02/9
  • Core/Insulation Crimp: A/5
  • Release Tool/Test Probe: 12094430/J-35616-35 (VT)
Engine Control Module (ECM) X2
Pin​
Wire​
Circuit​
Function​
1​
0.35 PU​
2121​
IC 1 Control​
2​
0.5 TN​
1664​
HO2S Low Signal – Bank 1 Sensor 1​
3​
0.5 PU/WH​
1665​
HO2S High Signal – Bank 1 Sensor 1​
4​
0.5 PU/WH​
1668​
HO2S High Signal – Bank 1 Sensor 2​
5​
0.5 TN/WH​
1669​
HO2S Low Signal – Bank 1 Sensor 2​
6​
0.35 L-BU​
1876​
KS 2 Signal​
7​
0.35 GY​
2303​
KS 2 Signal​
8​
0.35 D-BU​
496​
KS 1 Signal​
9​
0.35 GY​
1716​
KS 1 Signal​
10​
Not Available​
11​
0.5 YE​
581​
TAC Motor Control 1​
12​
0.5 BN​
582​
TAC Motor Control 2​
13​
0.5 PK​
839​
Ignition Voltage​
14​
0.35 BN​
2198​
Camshaft Position Actuator Solenoid High Control (LL8)​
15​
Not Available​
16​
0.5 PK/BK​
1746​
Fuel Injector 3 Control (LH6/LS2)​
17​
0.35 D-GN​
2125​
IC 5 Control (LL8)​
0.5 PU/WH​
2128​
IC 8 Control (LH6/LS2)​
18​
0.5 D-GN/WH​
2124​
IC 4 Control (LH6/LS2)​
19​
0.5 BN/WH​
2130​
20–22​
Not Available​
23​
0.35 PK/BK​
632​
Low Reference​
24​
0.35 PU​
114​
Low Oil Pressure Switch Signal (LL8)​
0.35 BK​
2755​
25–26​
Not Available​
27​
0.5 BK​
407​
Low Reference (LL8)​
0.35 YE/BK​
1868​
28​
Not Available​
29​
0.35 BK/WH​
1704​
Low Reference​
30–31​
Not Available​
32​
0.5 YE/BK​
846​
Fuel Injector 6 Control​
0.5 L-GN/BK​
1745​
Fuel Injector 2 Control (LH6/LS2)​
33​
0.35 L-BU​
2123​
IC 3 Control (LL8)​
0.5 RD​
2127​
IC 7 Control (LH6/LS2)​
34​
0.35 D-GN/WH​
2124​
IC 4 Control (LL8)​
0.5 D-GN​
2125​
IC 5 Control (LH6/LS2)​
35​
0.5 BN​
2129​
36–38​
Not Available​
39​
0.35 RD​
631​
12-Volt Reference​
40​
0.35 GY​
2705​
41​
Not Available​
42​
0.5 BK​
2760​
Low Reference​
43​
0.35 YE​
6259​
Starter Enable Relay Control (LL8)​
0.35 L-GN​
1867​
12-Volt Reference (LH6/LS2)​
44​
0.35 GY​
2701​
5-Volt Reference (LL8)​
0.35 L-BU/BK​
1688​
45​
Not Available​
46​
0.35 BK​
2199​
47​
Not Available​
48​
0.5 BK/WH​
845​
Fuel Injector 5 Control (LL8)​
0.5 D-BU/WH​
878​
Fuel Injector 8 Control (LH6/LS2)​
49​
0.5 L-BU/BK​
844​
Fuel Injector 4 Control (LL8)​
0.5 BK/WH​
845​
Fuel Injector 5 Control (LH6/LS2)​
50–51​
Not Available​
52​
0.5 L-GN/BK​
1745​
Fuel Injector 2 Control (LL8)​
0.5 YE/BK​
846​
Fuel Injector 6 Control (LH6/LS2)​
53​
0.35 L-BU/WH​
2126​
IC 6 Control (LL8)​
0.5 RD/WH​
2122​
IC 2 Control (LH6/LS2)​
54​
0.35 RD/WH​
2122​
IC 2 Control (LL8)​
0.5 L-BU/WH​
2126​
IC 6 Control (LH6/LS2)​
55​
0.5 L-BU​
2123​
IC 3 Control (LH6/LS2)​
56–58​
Not Available​
59​
0.35 BK​
630​
CMP Sensor Signal (LL8)​
0.35 BN/WH​
633​
CMP Sensor Signal (LH6/LS2)​
60​
0.35 TN/WH​
332​
Oil Pressure Sensor Signal (LH6/LS2)​
61​
Not Available​
62​
0.5 TN​
472​
IAT Sensor Signal​
63​
0.5 BN/WH​
633​
CKP Sensor Signal (LL8)​
0.35 D-BU/WH​
1869​
CKP Sensor Signal (LH6/LS2)​
64​
0.35 D-GN​
485​
TP Sensor 1 Signal​
65​
Not Available​
66​
0.35 PU​
486​
TP Sensor 2 Signal​
67​
0.5 YE​
492​
MAF Sensor Signal​
68​
0.5 D-GN​
676​
HO2S Heater Low Control – Bank 1 Sensor 1 (LL8)​
0.5 BK/WH​
3113​
HO2S Heater Low Control – Bank 1 Sensor 1​
69​
0.5 BK/WH​
1423​
HO2S Heater Low Control – Bank 1 Sensor 2 (LL8)​
0.5 BN​
2391​
HO2S Heater Low Control – Bank 1 Sensor 2 (LH6/LS2)​
70​
0.5 L-BU/BK​
844​
Fuel Injector 4 Control (LH6/LS2)​
71​
0.5 PK/BK​
1746​
Fuel Injector 3 Control (LL8)​
0.5 RD/BK​
877​
Fuel Injector 7 Control (LH6/LS2)​
72​
0.5 BK​
1744​
Fuel Injector 1 Control​
73​
1 BK/WH​
451​
Ground (LL8)​
3 BK​
451​
Ground (LH6/LS2)​
99982
  • OEM: 13608385 (LL8)/13574284 (LH6/LS2)
  • Service: 88988372
  • Description: 73-Way F 0.64 Series Sealed (GY)
  • Pins: 3–6, 9–11, 15, 26, 42, 48, 50, 62, 68, 69
  • Pins: 7, 12, 17, 21, 23, 29, 33, 35, 37, 39, 47, 53, 55, 57, 59, 65, 66
Engine Control Module (ECM) X3
Pin​
Wire​
Circuit​
Function​
1–2​
Not Available​
3​
0.5 TN​
1667​
HO2S Low Signal – Bank 2 Sensor 1 (LH6/LS2)​
4​
0.5 PU​
1666​
HO2S High Signal – Bank 2 Sensor 1 (LH6/LS2)​
5​
0.5 PU​
1670​
HO2S High Signal – Bank 2 Sensor 2 (LH6/LS2)​
6​
0.5 TN​
1671​
HO2S Low Signal – Bank 2 Sensor 2 (LH6/LS2)​
7​
0.35 PU​
5428​
Generator Regulator Control​
8​
Not Available​
9​
0.5 BN​
436​
AIR Pump Relay Control (LL8)​
10​
0.5 GY​
5493​
Cylinder Shutoff Solenoid Control (3) (LH6/LS2)​
11​
0.5 D-BU​
5491​
Cylinder Shutoff Solenoid Control (1) (LH6/LS2)​
12​
0.35 TN/BK​
464​
Delivered Torque Signal​
13–14​
Not Available​
15​
0.5 L-GN​
3212​
HO2S Heater Low Control – Bank 2 Sensor 1 (LH6/LS2)​
16​
Not Available​
17​
0.35 OG/BK​
463​
Requested Torque Signal​
18–20​
Not Available​
21​
0.35 BK​
2751​
Low Reference​
22​
Not Available​
23​
0.35 OG/BK​
469​
Low Reference​
24–25​
Not Available​
26​
0.5 D-BU/WH​
6785​
Air Injection Reaction Control Valve 1 Low Reference (LL8)​
27​
Not Available​
28​
Not Used​
29​
0.35 GY​
23​
Generator Field Duty Cycle Signal​
30–32​
Not Available​
33​
0.35 TN​
2501​
High Speed GMLAN Serial Data Bus –​
34​
Not Available​
35​
0.35 BK​
2761​
Low Reference​
36​
Not Available​
37​
0.35 GY​
2700​
5-Volt Reference​
38​
Not Available​
39​
0.35 GY​
2704​
5-Volt Reference​
40–41​
Not Available​
42​
0.5 BN/WH​
6789​
Air Injection Reaction Control Valve 1-Volt Reference (LL8)​
43​
Not Available​
44​
Not Used​
45–46​
Not Available​
47​
0.35 OG/BK​
1786​
PNP Switch Signal​
48​
0.5 D-GN/WH​
428​
EVAP Canister Purge Solenoid Control​
49​
Not Used​
50​
0.5 RD/WH​
3223​
HO2S Heater Low Control – Bank 2 Sensor 2 (LH6/LS2)​
51–52​
Not Available​
53​
0.35 TN/WH​
2500​
High Speed GMLAN Serial Data Bus +​
54​
Not Available​
55​
0.35 YE​
410​
ECT Sensor Signal​
56​
Not Available​
57​
0.35 RD/BK​
380​
A/C Refrigerant Pressure Sensor​
58​
Not Available​
59​
0.35 L-GN​
432​
MAP Sensor Signal​
60–61​
Not Available​
62​
0.5 YE​
6787​
Secondary Air Injection Pressure Sensor Signal (LL8)​
63​
Not Available​
64​
Not Used​
65​
0.35 TN/BK​
231​
66​
0.35 RD​
381​
Signal High – Front​
67​
Not Available​
68​
0.5 L-GN​
5492​
Cylinder Shutoff Solenoid Control (4) (LH6/LS2)​
69​
0.5 OG​
5494​
Cylinder Shutoff Solenoid Control (2) (LH6/LS2)​
70–72​
Not Available​
73​
Not Used​
99987
  • OEM: 13511976
  • Service: 88987979
  • Description: 49-Way F GT 280 Series Sealed (BK)
  • Pins: 1–3, 5–7, 11, 14, 16, 17, 20, 23–25, 29–33, 35, 37–42, 44–46
  • Terminal/Tray: 15359541/4
  • Core/Insulation Crimp: M/M
  • Release Tool/Test Probe: 15381651-2/J-35616-64B (L-BU)
  • Pins: 49
  • Terminal/Tray: 15304720/19
  • Core/Insulation Crimp: 4/5
  • Release Tool/Test Probe: 15315247/J-35616-4A (PU)
Transmission Control Module (TCM)
Pin​
Wire​
Circuit​
Function​
1​
0.5 BN​
418​
TC  PWM Solenoid Valve Control​
2​
0.5 L-GN​
1222​
1–2 Shift Solenoid Valve Control​
3​
0.35 OG​
1983​
ISS Signal​
4​
Not Available​
5​
0.35 RD​
381​
6​
0.35 L-BU/BK​
6106​
High Speed GMLAN Serial Data Bus − (CAN)​
7​
0.35 D-BU​
6105​
High Speed GMLAN Serial Data Bus + (CAN)​
8–10​
Not Available​
11​
0.35 YE​
243​
Accessory Voltage​
12–13​
Not Available​
14​
0.5 WH​
687​
3–2 Shift Solenoid Valve Control​
15​
Not Available​
16​
0.35 L-GN/BK​
822​
VSS Low Signal​
17​
0.5 L-BU/WH​
1229​
PC Solenoid Valve Low Control​
18–19​
Not Available​
20​
0.5 YE/BK​
1223​
2–3 Shift Solenoid Valve Control​
21–22​
Not Available​
23​
0.35 GY​
773​
Transmission Range Switch Signal C​
24​
0.5 PK​
1224​
Transmission Fluid Pressure Switch Signal A​
25​
0.5 TN/BK​
422​
TCC Solenoid Valve Control​
26–28​
Not Available​
29​
0.35 BK/WH​
771​
Transmission Range Switch Signal A​
30​
0.5 BK​
2762​
Low Reference​
31​
0.5 PK​
139​
Ignition 1 Voltage​
32​
0.35 OG​
540​
33​
0.5 RD​
1226​
Transmission Fluid Pressure Switch Signal C​
34​
Not Available​
35​
0.5 YE/BK​
1227​
TFT Sensor Signal​
36​
Not Available​
37​
0.35 TN​
2501​
38​
0.35 TN/WH​
2500​
39​
0.35 WH​
776​
Transmission Range Switch Signal P​
40​
0.5 RD/BK​
1228​
PC Solenoid Valve High Control​
41​
0.35 PU/WH​
821​
VSS High Signal​
42​
0.35 L–BU​
1320​
Stop Lamp Switch Signal​
43​
Not Available​
44​
0.5 D-BU​
1225​
Transmission Fluid Pressure Switch Signal B​
45​
0.35 L-BU​
1984​
Low Reference​
46​
0.35 YE​
772​
Transmission Range Switch Signal B​
47–48​
Not Available​
49​
2 BK/WH​
451​
Ground (LL8)​
2 BK​
451​
Ground (LH6/LS2)​
1 - 19 of 19 Posts
