1 - 12 of 12 Posts
Just installed my Euro lights with DDm's HID kit. Everything worked perfectly. Now im installing Jetttstream's DRL killer with auto and quad highs. I attached everything just like the directions said and now the low beams wont turn on at all, even with manual switch on and towel over light sensor and gear selector in drive. What could be the problem. I cecked the fuses under the hood and they are fine. All other lights work even the high beams. lows just wont turn on any ideas ????????????????????????????????
i could take it off and reconnect the wires together for now i guess. wont to try to fsee if i can get it to work before i do that tho
Discussion Starter · #10 ·
just checked and is not the HIDs checked low beam connector and its not getting any juice. could it be a bad relay in the DRL killer?
got it fixed. checked connections and one of the connectors was bent and not connecting to splicer's. all is now good. thx for the help guys :yay2::bigarmhug:
1 - 12 of 12 Posts
