1 - 16 of 16 Posts
TrailblazerSS AWD
So I lost gears 3 and 4 on the highway today. I'm having a super duty 4x4 4L70e built by monster. They asked me what pin connector my Trans has. They said it's either a 13pin or 15pin. I contacted a Chevy dealership and they didn't know.
:wtf:
Its the round plug on the right side of the trans. You'll have to pull it and count the pins.
What year is it. Someone might know already.
TrailblazerSS AWD
2006 awd
'08 TrailblazerSS
Its a 20 pin connector but only 15 pins are used.
TrailblazerSS AWD
I'll give monster that info and see if it helps. worst comes to worse I guess I'll have to try scrape the jack under my frame and pull the plug.....should I expect to have fluid leak if I do this?
'08 TrailblazerSS
TrailblazerSS AWD
Oh, it's an electrical unit. the picture they sent me looked like a bolt that connects to the Trans fluid pan
Sure you want them building you a trans then?
TrailblazerSS AWD
Discussion Starter · #9 ·
Big name company used for builds for overhaulin and other car builds found on velocity and speed network. They probably assumed I knew what they were talking about. Thank you for your help
Considering all 70e have an ISS im sure its a 15. Thats the only difference i could think of. You would think they would know such info? Maybe im wrong.
TrailblazerSS AWD
Discussion Starter · #11 ·
They state on their site that 70e's have the 15 pin. They wanted to know what mine had only because it is a 2006. Did they use a 60e when they first started the ss line?
No not that I'm aware of.
TrailblazerSS 3SS
I am building a test connector set, does anyone happen to know the part number of the connector on the right?
I would appreciate it greatly.
'08 TrailblazerSS
15443076
'08 TrailblazerSS
I think 15443076 is an old number. I found a couple part numbers, 15305804 and 13510422. I found an ACDelco part number PT921. It comes with leads.
TrailblazerSS 3SS
Thats what I needed, thanks Branndon
1 - 16 of 16 Posts
