1 - 13 of 13 Posts
How much material is needed to grind off for spindle clearence ?
I bought a used set from a member and these are not clearenced by Tony.
Can someone give/measure the dimensions of the "slot" needed?
I`d like to know that so I can grind it or take it to local shop and after grinding send it to powder coating for better looks and it would save me alot of trouble/effort.
Thanks,
Pete
2008 Trailblazer SS
do they NEED to be ground down?? I dont think mine are....
In this pic (courtesy of NORCAL SS) looks even with the ball joint mount but I'm not positive. I'm sure someone that has them will chime in... I also would like to know.
2008 Trailblazer SS
im going to be tightening up the suspension over the next couple of weeks. I assume that since ive been driving with the non shaved (bald!) a-arms i would see where the contact has been so that would be where to grind it down, no?
This is what NorCal SS says:
1) disconnect lower strut mount from a arm and pop out strut
2) pop off sway bar off a arm
3) jack up the lower control arm till you see the spindle touch the a arm
4) notch accordingly until the spindle clears the a arms
5) if your higher than 31.25 you dont need to worry about this.
Administrator
it hits at 31.5 also.
Administrator
thread must be pretty old thats why trying to get info out here.
moar cowbell
Trailblazer
just do this and you'll be good
Discussion Starter #13
I would, but this is my DD and I want as little down time as possible.
And since these arms were bought used, they are in little rough shape and I would like to repowder coat them before I put them on.
Pete
1 - 13 of 13 Posts
