1 - 13 of 13 Posts
07TrailblazerSS
Just did a trans oil and filter change as well as a tune. i now have a random problem. When driving, as the trans shifts uo to 4th then i decelarate and when i go to lightly push on the throttle, i get no response....In other words the motor doesnt rev nor the trans. It acts like there is a dead spot. Its happens usually between 30-50 mph when decelarating. PLEASE HELP!!!!
TBSS 3SS
I'm thinking its the tune. Record a session then post it here.
07TrailblazerSS
Anyone else?? TPS sensor?
2007 Trailblazer SS
Probably something to do with the way they reduced torque management. ( if they did.) Happened to me shortly after I got HPtuners and I was messing around seeing what did what.
07TrailblazerSS
They did reduce the torque management. What specific questions would you advise me on asking my tuner to check or change to fix this problem. THANKS
If it didnt do it right after the tune, but a few days later, my question would be did you put in an aftermarket air filter with oil on it? Allot of times a few days after that, you need to clean your MAF with MAF cleaner. Would be the most likely cause if its not the tune itself. Try it, costs under $10. Then if it doesnt work, call your tuner, he will know what to do and what to check.
07TrailblazerSS
Discussion Starter · #10 ·
Cleaned the MAF weeks before the tune as well as cleaned and very lightly oiled the filter
If you oiled the filter at the same time you cleaned the MAF, thats probably it. Its the NEW oil that took a few days to work its way to the MAF. I bet thats it, clean it again, bet theres oil on it. Hey its an almost free fix, so it cant hurt to try it. Youd be surprised what an oily MAF will do.
07TrailblazerSS
Will do! Thanks for your input:coolthumb:
07TrailblazerSS
Discussion Starter · #13 ·
thats why I really wished these things were cable controlled! IMO you would get better throttle response and control
:iamwithstupid:
1 - 13 of 13 Posts
