1 - 9 of 9 Posts
Are you able to show your speed and oil temp? I can seem to find it. That's the reason I nought it was so I can view my Speed, ECT, trans temp, and oil temp and so far I found ECT,trans temp and that's it. Any help on which sub group to find them
04 NBSCC Silverado
Chase, go to
menu
Setup
display
Pick which display ( 1-10)
What type of graph
Select parameter to edit
Then it is under
GM specific pids/GM sensor pids
Ahhh thank you I'll take a look in a sec!
Jose ur slow to responde lol
Now what os speed under?
Found it!
Chase go here: http://www.dashhawk.com/downloads.html
You should be able to download the instructions for it here. You can see almost anything you want with it. You can setup any parameters you want. Those are just the ones I had setup for what I cared about for my truck. Honestly you can setup so much stuff to view on it that it can take forever to go through and setup up.
Just know that not every parameter that is in the DH is supported by every vehicle. Some things you will have to try by trial and error.
1 - 9 of 9 Posts
