You will need the below items and a few clamps. I cut 1" off of the 4" diameter Hump Hose and then joined all of the with 4" aluminum tubing inside of the joints. This way when assembled you dont see anything except the rubber tubing.
http://store.airflo.com/rubber-hoses---clamps.html
(1) K&N E0773
(1) Rubber Hump Hose 4"
(1) Rubber Intake Elbow Short Radius 90 Degree 4"
(2) Rubber Intake Elbow 45 Degree 4"
(1) Reducing Hose Insert 4" to 3.75"
(1) Reducing Hose Insert 4" to 3.5"
(1) 12" section of 4" Diameter Aluminum Tubing
**You will need to cut the aluminum into (3) 4" long sections.
(1) K&N E0773
