1 - 7 of 7 Posts
High and Tight!!!
What BS/width should I run on the rear Bogarts to fit a 325 AND 390 M&H? I was planning to order 17x10 with 6.5bs but I want to clarify whether the 390 will fit with that backspacing/width or if I have to go with more?
Check with with wes, he recently bought a setup from bogarts to run a 390 tire. He would have the info you need. His bolted right up and didn't have any clearance issues
High and Tight!!!
Thats not what I heard. :biggrin2:
High and Tight!!!
I have been talking with Rich. He explained a few of the issues with Wes's wheels. I would like to have some like his because he has a new design with the valve stems on the inside of the wheel, but Wes and Rich have both mentioned some issues. Rich recommended a 6.5bs.
Now u said for correct BS and I knew about the valve stem issue. But looks like u already knew that.. :)
High and Tight!!!
:dunno: Wes's rears fit prefect so im going to try to replicate his in an RR10.
1 - 7 of 7 Posts
