1 - 8 of 8 Posts
Hater
Duh
So I exit the freeway after my 20min commute and come to a light and smell coolant. I get home a couple mins later and pop the hood and the smell is strong. I can see coolant spray on the cross member, the side of the washer resv. and on the fram under the a/c compressor. All the hoses are snug and i cant find it dripping from anywhere. Everything around the water pump is dry and not stained. Also the coolant tank was low so I added. And two days ago when I drove it last, it got a bath and the coolant level was good. I have 5 month old jetttstream radiator hoses but they dont appear to have any holes. Dashhawk showed temp was normal. Any ideas?
Have you looked under the hood while the vehicle was running? It might be a pin size hole that a naked eye will not be able to see.
I believe so. It might be leaking from the lines coming from the reservoir its if the washer tank has traces of coolant. I've had to replace those lines before.
06 3SS
I had a similar issue. My leak was between the AC condenser and radiator. The foam between the two was soaked. Turns out it was leaking where the plastic end tank crimps to the core. Rockauto.com has a OEM replacement for $150 and it was a drain plug on it.
Hater
Duh
it was definately coming from where the lower radiator hose meets the water pump. The clamp wasnt loose but it wasnt tight either...there was a little coolant on that clamp. SO i tightened and its not leaking now...hopefully that was it
1 - 8 of 8 Posts
