1 - 7 of 7 Posts
Sabb 9-7X
Is this the code for the sensor at the pedal or the code for the sensor at the tb? Is the tps sensor at the tb serviceable by itself or do I need an entire tb? Thanks for the help!
07GroceryGetter
Well...... When mine threw that code, it was under warranty. I took it to the dealer and they replaced the pedal switch. Drove it for about a week and of course same code and problem. Took it back to the dealer and they replaced the tb, haven't had a problem since then but now it has a maggie and different tb. Is it the original tb?
Sabb 9-7X
Yes it's the original tb. I cleaned it, cleared the code, did the TB relearn. So far so good.
Is it a ported TB by any chance? If so, over porting can cause this.
Just disable the code if it is.
Sabb 9-7X
It's bone stock. Light is still off. If I do end up needing a new sensor do I need an entire new Tb or just the sensor?
97-X Aero
You can do just the sensor. I ended do the whole throttle body on my work truck. Just because it was easier.
1 - 7 of 7 Posts
