1 - 8 of 8 Posts
Help find a gates fleet runner hd belt, which one do I get?
So the belt that came with my blower is part # K061098, but they dont make that size in the gates fleet runner hd. Which one are you guys running? thanks for your help
The Master Baiter
Whats the difference between the gates and this one? Can I only get the fleet runner if I have the 8 rib setup? Thanks for your help.
The gatorback has grooves in it that are perpendicular to the ribs on the belt. It literally looks like a "gators back." I used one until I went to the 8 rib and it worked out great. Didnt have belt slip until I started going below a 2.9....then I went 8 rib.
sweet, Ill check it out. Im running the 3.0 and Im seeing around 9lbs. Thanks for the help
You need the Fleet Runner for the RIP Supercharger Pulleys. We have the RIP Pulleys in 6 and 8 Rib now.
You can go up or down in the length a little. You have an adjustable idler to dial in the position of the tensioner.
1 - 8 of 8 Posts
