1 - 8 of 8 Posts
Hi i have a ls3 out of a 13 corvette engine that ima be putting into a 69 chevelle so i have the oil pan and pick up tube from the c6 that i wanna go ahead and put on my 2wd 07 tbss. Where can i buy the ac bracket that ima be needing and also where can i see instructions on how to do it. My last question is if i turn my crossmember upside down and drill new holes will that work instead of cutting it?
'07 3SS 2WD
This is for the C6 pan.
Cool thank you let me check it out. Do u know if i can use the stock pick up tube from the c6 or is it a different one?
Contact LeftCoast32. They sell everything you need to do the conversion.
Lighter-than-you
It's not drilling holes thats the pain, it's how much you have to cut-up and butcher the stock x-member to make it work... Then it's also unsafe bc wasn't designed to be mounted upside down.. Lastly it looks about as ghetto as it sounds. There are at least 3 different options for aftermarket x-member's now that are safe and professional-looking.
I been looking around for them thank u
expensive but worth it is the simple-engineering crossmember. This is what i have
There is also one from a guy on facebook that is more sheet metal and includes an undertray . Where as the simple engineering kit the umdertray/brace is optional
1 - 8 of 8 Posts
