1 - 8 of 8 Posts
I’ve seen many guys saying they did the c6 pan upgrade but no source on where they got it from? I seen some sites listed and they look really sketchy. Any help?
GM Part # 12624617
Pretty easy search
GM Part # 12624617
Pretty easy search
I seen those I was trying to find more of a general part that everyone is using.
Why would you want a general part when the dude just gave you three of the exact part with the part number from GM?
When I was saying general I was referring to what’s are some options everyone has used for this problem. I’ve seen options where it says it works/fit for ls2 and people had headaches with it.You can google search it and see prices from $250-$600.
Are you set on the c6 pan and new crossmember?
there is also the pcmofnc oilpickup which is cheaper
and there is the oil pan baffle that is about $30.
i have to pull the motor out already and I have talked with a few guys who has done the pcm pick up and did that and still ended up switching over to the pan after I posted this. I bought the pan from summit and the crossmember from Boltonspeed
1 - 8 of 8 Posts
