1 - 14 of 14 Posts
Has anyone bypassed the radiator cooler completely? I think coolant may be leaking into my transmission. Trying to see if I may be able to save my transmission. Just started to act up yesterday. I was wanting to retain the factory lines. Has anyone done this?
06' Red Jewel 3SS,
Yes it can be done. Be sure to get a large enough cooler for the heat load.
I tried to search but I didn't see anything on retaining the factory lines while bypassing the radiator completely
06' Red Jewel 3SS,
You’ll have to add some kind of adapter and use some flex lines from the factory connections. Sorry I don’t know exactly what hardware sizes you need.
your tranny will be done soon if you had coolant in it. the stuff absorbs through the clutches causing rust on the steels then the clutch lining will start popping off :(
I skipped the transmission cooler in the radiator when I put the truck back together. I did not want to have this same issue if the radiator fails. I would recommend getting a new coolant only radiator and a stand alone cooler for the transmission.
Reactions: timg
If you buy a tru-cool 40k trans cooler, it will come with everything you need from brackets to hoses. If you need pictures of install I'll post them up for you.
The trans having coolant in it needs a complete soft flush to get any possible contamination out of there. If you continue to drive it, you're gonna kill it.
Get 4 gallons of dexron 6 (give or take), disconnect the hard lines from the radiator and have a big drain pan for all the fluid to go into, then start the truck. Pour trans fluid in through the trans dip stick tube while the old fluid is coming out. Once you feel you have got all the crap out, shut the truck off and install your new cooler. This way you can get the fluid out of the converter as well.
Then drain the trans pan and remove and replace your trans filter. Top off again. Check periodically to make sure it's toped off after you drive it a bit.
Sent from my Pixel 3 using Tapatalk
Yes thanks for the information. I actually went and got two big wide pans from AutoZone yesterday and they came in handy. I'm ready to flush it tomorrow. Please post pictures of your install when you have time. Thanks alot
Discussion Starter · #9 ·
One more thing. When I bypass is it safe to leave the radiator ports open where the transmission lines went? I know there isn't anything that should be flowing out right if unplugged? It should be dry?
06' Red Jewel 3SS,
Mine are open and I haven’t had any issues. It’s been years since it was bypassed.
It's fine to leave them open. Any residual trans fluid will leak out but thats it.
'07 3SS 2WD
Leaving them open will definitively tell you if indeed the radiator was leaking into the trans lines.
'07 3SS 2WD
Anybody have links to the female fittings that fit the OE hard lines? I'm going to be installing a stand alone cooler, and would like to just tie into the lines at the bottom of the radiator. Is there a socket to male AN fitting available?
1 - 14 of 14 Posts
