1 - 10 of 10 Posts
I have for sale a TVS 2300 designed for a TBSS with L92/LS3/LSA Heads.
This is one of Joe’s kits from LeftCoast32 that fits the truck accessory drive of the Trailblazer.
House and kids have taken priority over this build and I don’t see myself able to use this in the near future.
I’m asking $8,000, I have about $11,235 invested in this setup so it’s priced to sell already.
I will only part things out if the supercharger sells first to someone that doesn't want all of the other components.
Not interested in any trades, cash is king.
Also will accept PayPal as long as you cover all the fees.
I am located in Southern Virginia. I can't cover the shipping on these but I would be willing to drive a couple of hours to meet halfway if needed.
What's included:
Jackshaft TVS 2300 Supercharger w/ hardware kit 7,300.00
Billet Front Inlet 102-105mm (raised) 1,050.00
Professionally matched powdercoat of billet inlet by HighSpeedLab 89.00
Overdrive Cog Rear Drive 400.00
Reinforced Front Idler Support Bracket 275.00
HD Tensioner Kit 179.00
Extra Fuel Rail Blank 75.00
Water Pump Pulley Nut (Bare finish) 22.00
Innovators West 10% OD Balancer 500.00
8 Rib Pulley Kit 500.00
HD Tensioner Aluminum Shouldered Pulley 155.00
3.0 RIP 8 Rib Pulley 135.00
Tensioner Support Bracket 70.00
RDS Blower Spacer (1/2") 450.00
HPS Silicone 4.25" to 4" reducer 56.00
Aluminum 4" elbow (long 90) 29.00
This kit includes a TVS2300 with jackshaft pulley spacing for the TBSS accessory drive and a TBSS hardware kit. Elbow and coupler for the 102mm raised inlet to be able to connect to a PCM 4" intake. The extra fuel rail can be used for a dual feed system where the fuel feeds both rails at the same time. The phenolic blower spacer is a direct fit between the blower manifold and the tub to prevent heatsoak. The 1/2" increased height will not cause any firewall/hood clearance issues in a TBSS. You will just need to account for the increased height when choosing fuel injectors for your setup.
101848
101849
101850
101851
101855
101856
101857
101858
Discussion Starter · #2 ·
Still available. Bump.
Bump
Thanks for the interest. I'm only willing to part this out if the supercharger sells first. I won't separate the other components until I know that whoever buys the blower doesn't want/need them.
If anyone already has a 1900 or nose drive 2300 and wants to upgrade to LS3 heads and the jackshaft 2300 I will sell just the blower with or without the Magnuson parts box and other components.
Where did you get the modified snout from?
Discussion Starter · #8 · (Edited)
The modified snout is a LeftCoast32 part. It came from Joe.
Lots of people asking about this blower since tax returns and stimulus checks but nobody has pulled the trigger. Still available.
Hater
Duh
A simple lower tub swap for cathedrals could be done correct ?
Discussion Starter · #10 · (Edited)
1 - 10 of 10 Posts
