Hi all,
Just installed power stop calipers, drilled and slotted rotors, and s.s. brake hoses. Bled system. When I got to the passenger front apparently I let it get too low and master cylinder went dry. Filled it back up and continued bleeding but found I was barely getting any fluid out. Went to the driver's front and wasn't getting any fluid out. Apparently, I need a tech 2. Anybody around Grand Blanc Michigan with a Tech 2 to cycle the ABS? I'm between a rock and a hard place and not able to take it to the dealer.
