1 - 8 of 8 Posts
Administrator
Ill have pics up soon. $161.90 shipped to your door
http://www.rpmoutlet.com/store/sc/o...tion=http://www.rpmoutlet.com/03cobraheat.htm
Here is what you need to move it all
Heres the parts i used
battery box 69 bucks
http://store.summitracing.com/partdetail.asp?autof ilter=1&part=SUM%2DG1231&N=700+115&autoview=sku
postive terminal fitting 19 bucks
http://www.knukonceptz.com/productDe...prodID=KBT-30N
negative terminal fitting 19 bucks
http://www.knukonceptz.com/productDe...prodID=KBT-30P
25 feet positive 0 guage wire power red 80 bucks
http://www.knukonceptz.com/productDe...m?prodID=KFX0R
5 feet 0 gauge ground black wire 16.25
http://www.knukonceptz.com/productDe...?prodID=KFX0BK
inline fuse with 200 amp fuse 20 bucks
http://www.knukonceptz.com/productDe...m?prodID=FH-20
Ring terminals (2 per box 3 needed) 19.50
http://www.knukonceptz.com/productDe...m?prodID=SSRT0
then some grommets, wire loom and zip ties your done.
07 AWD TBSS
G
Great find Tony. Canton wants $200 for the same tank but I think without the battery relocation box & accessories
Administrator
The battery relocation kit they have is junk compared to the one i got. I put up the stuff needed and if your going to do it right might as well go all out.
'07 2wd
Hey Tony, any thoughts of putting a Dyna-Batt in the rear compartment with the air outlet? It would fit. I have used the battery before with good results but nothing long term.
Administrator
ps not sure i have the yellow top and its heavier which helps with traction. Im sure you could get that one to work for you.
Administrator
im going to take some today. Just been busy. The shop i was going to have it powdercoated at dropped the tank and fucked it up. They bought me a new tank and im going to another shop to get it done now cause they tried to give me the bent unit back which was bs.
1 - 8 of 8 Posts
