1 - 6 of 6 Posts
What is the best intake manifold and heads to run with Rob style cam? I tried searching but couldnt find anything!
The rob cam is designed to work with the stock heads and intake. If you plan on making more power by changing the heads and intake then contact form member lt1z for a custom grind cam
If your staying NA then the fast lsxrt and a set of AFR or TFS heads would work best.
Reactions: Billbillracing
My tbss is stock except for efan and cai. Is there any power to gain if i install a Rob cam with stock exhaust manifolds?
You will still gain some power but youre better off running headers so the engine can breath.
1 - 6 of 6 Posts
