1 - 18 of 18 Posts
OK went to go see some tires today, told the guy I wanted 275/45 R20. He told me they were taller then the 255/50 R20, I thought they were smaller?
He even brought some out for me to see, they look HUGE! Given theres were not mounted.
Question is are the 275 taller? I thought they were a tad smaller in height and wider then the stock 255? Also do they just look big because they are not mounted yet?
I'm sure they are slightly smaller, I used discount's tire size calculator and it said they were smaller.
I have them, they're a tad shorter, and a tad wider. thats about it. A lot more options too.
2007 AWD - 3SS TBSS
The Atturro's are taller than 255/50R20's, but they fit no problem... They are as tall as 265/50R20's which also fit on our wheels....
07 TrailblazerSS Imp
David is correct. I have the Aturro's and they are 30.4" tall. Most 275/45's are in the 29.9" range and the stock 255/50 is 30.1"
Discussion Starter · #7 · (Edited)
Sweet ill return on Tuesday and see what he has in that size. Thanx All! :coolthumb:
Definitely wanted wider but not taller.
So the part where they look taller unmounted on anything is because of that right? Once mounted they should look ok?
Or should I go with 275/40? Dont plan on lowering her for a while, so with the 40 will I get a bit of a lower stance? Without harm?
Resident Asshole!
2007 Tahoe
TBSS21, From a quick Google, it looks just like the Falken ST/Z-04's, which I had... The Falken's were an awesome tire... Quiet, Bidirectional, and awesome in ALL seasons.... Not bad on pricing... I think I paid maybe 500 shipped for all four... and easily got over 50k miles on em all.
I have 275/40/20 I like them but maybe on a suv it's really not recommended
2007 AWD - 3SS TBSS
Discussion Starter · #13 ·
Thanx guys, I expected some bad words about the tires but they seem to be alright. I'll stick with them, prolly get them tomorrow.
Discussion Starter · #15 · (Edited)
Ok so I noticed the truck is wobbly if I swerve the steering wheel a bit while at freeway speeds. Seems like a tad loose up front. Checked the air in the tires and found it to be 41-46 varying all around so I dropped the fronts to 35 left the rears at 40. Helped a bit but still feels the same.
Spoke to the guy at the tire shop I went to, he said I went with a bigger sidewall tire so that’s why I feel it wobbly, this true? Said he would do a pre alignment to see if it was off before actually doing it.
Question is again I thought this size was a tad smaller and wider, is he not correct? And do I need an alignment? Or am I just feeling it like this because of the new tires, keep in mind I wore out the old RSA's to the point they looked like slicks but the steering felt more stiff.
Oh and the tire guy said the 255/50 were more of a low profile tire than what I put on there now?
:dunno:
Discussion Starter · #17 · (Edited)
Stock Tire - 255/50R20 New Tire - 275/45R20 Section Width: 10.03 in 255 mm Section Width: 10.82 in 275 mm
Rim Diameter: 20 in 508 mm Rim Diameter: 20 in 508 mm
Rim Width Range: 7 - 9 in Rim Width Range: 8.5 - 10 in
Overall Diameter: 30.03 in 762.76 mm Overall Diameter: 29.74 in 755.39 mm
Sidewall Height: 5.01 in 127.25 mm Sidewall Height: 4.87 in 123.69 mm
Radius: 15.01 in 381.25 mm Radius: 14.87 in 377.69 mm
Circumference: 94.34 in 2396.2 mm Circumference: 93.43 in 2373.1 mm
Revs per Mile: 692.6 Revs per Mile: 699.3
Actual Speed: 60 mph 100 km/h Speedometer1: 60.5 mph 100. km/h
Speedometer Difference: - Speedometer Difference: 0.967% too fast
Diameter Difference: - Diameter Difference: 0.97%
Thanx for the link, so he does not know what he is saying from what I can tell.
1 - 18 of 18 Posts
