1 - 17 of 17 Posts
I wanted to see if anyone has relocated there batter to where the spare tire goes?
I know some people have moved them into the hatch but I really dont want to do that.
Lets see your pictures.
Thanks
Chris
TrailBlazer SS
http://www.tbssowners.com/forums/showthread.php?t=51631&highlight=ssr+battery
I used the relocation kit with the cables from Summit. I used the real long one they have and soldered all new ends on the cables.
The battery box is an SSR Factory Box that can be purchased from MikeinAZ on here. I can help you hook it all up once you have everything.
The SSR Battery Box only needs 1 bracket made to bolt in under the back where the spare is - http://www.tbssowners.com/forums/showthread.php?t=20316&highlight=ssr+battery+relocation
You can also use any vented box for the interior, or a non-vented with a gel cell battery like an Optima - http://www.tbssowners.com/forums/showthread.php?t=28790&highlight=ssr+battery
Installed the Stand Alone Fuel System/Intercooler Reservoir Tank.
Had to relocate the battery to the back, I used the SSR drop down battery box.
We will be doing a new rear bumper support/hitch delete so we can place the kill switch and jumper posts where the hitch is now.
2006 Red Jewel AWD
I'd put a AGM or Gel Cell on the outside of the frame rail behind the driver's side of the rear bumper (Behind wheel well) honestly...
07 TrailblazerSS Imp
Thanks
Chris
Battery relocation Picuters.
I wanna know what a picuters is first? :burp: Sounds like something Wongbob would say after a case of Shiners. :D
TrailBlazer SS
Arocdnicg to rsceearch at Cmabrigde Uinervtisy, it deosn’t mttaer in waht oredr the ltteers in a wrod are, the olny iprmoatnt tihng is taht the frist and lsat ltteer are in the rghit pcale. The rset can be a toatl mses and you can sitll raed it wouthit pobelrm. Tihs is buseace the huamn mnid deos not raed ervey lteter by istlef, but the wrod as a wlohe.
Now what :bicz: :domo-kun:
1 - 17 of 17 Posts
