1 - 15 of 15 Posts
Saab 9-7X
I've fought with my PAC SWI-PS for years. It never worked as it should, even after the capacitor 'fix'. Occasionally it would work perfectly, sometimes it would respond slowly and only to certain button presses, but most of the time it didn't work at all. It was bad enough, that 95% of the time, my steering wheel controls didn't work at all. Over the course of a single drive, they would stop/start responding. For a while, it would even randomly change channels even though I didn't push any buttons...
Today, I swapped in an Axxess ASWC after someone on here mentioned that it was better than the PAC SWI-PS. The wiring was easier than the SWI-PS and so far it's working far better than the PAC SWI-PS ever did. The head unit responds as quickly as the stock unit did and all buttons have worked 100%. If you replace your radio and want to maintain steering wheel controls, I can't recommend the Axxess ASWC highly enough.
Tim
Saab 9-7X
You have to either solder, tap, or crimp three wires (switched power, ground, and signal). All three can be found in the factory or aftermarket wiring harness. I tapped directly into my GMOS-04 wiring harness.
Tim
2008 TbSs
Tim
Thanks but it seems like a lot of work..
Just used one them on my 05 silverado....simple install and works great!
I have to order this
Just put mine in. Anyone run into this problem though, I accidentally hit the button with the screaming face button and it immediately killed the radio. Only reason it did not scare the shit out of me is because it already did when installing the PAC so I knew it wasn't dead. Anyone know why it would do this. I don't have any other modules hooked up because I don't have blose, on star or chimes. It is easy enough for me to avoid this button but for the few, and I mean very few and far between, times wifey drives the truck I don't want her to accidentally hit it and get freaked. thanx
Saab 9-7X
Discussion Starter · #15 ·
It's the OnStar. There's something with the wiring that does that with every aftermarket radio. One of the guys on here posted a wiring diagram to bypass that 'feature'.
Tim
1 - 15 of 15 Posts
