1 - 7 of 7 Posts
You will have nasty camber. Your inner part of your wheel will rub to the cord
What will that kit have me sitting at? How will it ride compared to stock?
Administrator
if you dont want to use the a arms get the drop struts and use the 16mm spacer. that will dro you 1/2 inch over stock.
Administrator
with drop struts the ride is fine and in rear shock/spring combo better than stock which people will agree on that have done the swap.
in front the drop struts with 16mm spacer NO upper modified djm uppers are needed but with the 8mm spacer they will be.
and that will put you at 31.5 all the way around? im a n00b. do the rears "adjust" or once they're installed they sit where it should?
1 - 7 of 7 Posts
