Im thinking of running the bfg 285/35R22 anyone know if the'll fit a stock height awd?
WILLIAMJRDN · Some PCM of NC bolton's Joined Jun 7, 2007 · 9,639 Posts Discussion Starter • #1 • Jun 11, 2007 Im thinking of running the bfg 285/35R22 anyone know if the'll fit a stock height awd?
checo3423 · Premium Member TBZ06 Joined Jun 5, 2007 · 7,058 Posts #2 • Jun 12, 2007 Should be just fine, check the link out below. http://www.miata.net/garage/tirecalc.html :cheers1:
B BBA · Premium Member 2007 AWD 3SS Joined Jun 6, 2007 · 8,588 Posts #3 • Jun 13, 2007 If you had the wheel wide enough and a spaced right you could run 295 35 22 and have the speedo reading correctly. 60 MPH speedo reading would be 60.2 MPH actual speed...when the tires is new, slight mileage wear and it would read perfect.
WILLIAMJRDN · Some PCM of NC bolton's Joined Jun 7, 2007 · 9,639 Posts Discussion Starter • #4 • Jun 14, 2007 Thanks guys
