1 - 14 of 14 Posts
After all said and done the bill was 6461.89 I drove it 1200 miles did not launch it once all highway miles 3rd and 4th gear I felt it skip yesterday on the highway a grand or two and it blew out today. What could be the mechanics issue did he not soak the clutch bands? to make them burn out so fast? any help would put me in the ballpark for questions to ask...Anyone's opinion will help me.thank you Font Newspaper Paper Paper product Publication
There are a lot of reasons from clearances to proper shims and the right application of bearings in the right direction…. You wouldnt get an honest opinion from the same shop that built it to tell you why it failed
a reputable shop should have warrantied it for you. I had a very similar experience where my new level 5 transmission failed after 6 months exactly, which coincidentally was when my warranty expired. I was lucky enough to have conducted business with a good person. He completely rebuilt it again free of charge. You should press them to do the same.
very reputable shop they came highly recommended in my area he has done quit a few rebuilt t.b.s.s He gave me a one year or 12000 mile warranty up to 650 h.p and is standing by his work. would be no charge but I'm having him put in a transmission cooler for an extra $300 this Monday thank you all for the information given
TrailblazerSS 3SS
Was it just burnt clutch packs, and which one, if they have got it apart yet
After all said and done the bill was 6461.89 I drove it 1200 miles did not launch it once all highway miles 3rd and 4th gear I felt it skip yesterday on the highway a grand or two and it blew out today. What could be the mechanics issue did he not soak the clutch bands? to make them burn out so fast? any help would put me in the ballpark for questions to ask...Anyone's opinion will help me.thank you View attachment 103198
What was "skipping"?
Clutches and bands will get as wet as they can in just a few moments after each first shift - so dry "bands" and clutches is a non-problem.
Many shops (and I) built with dry parts to set the clearances and they will be wet before the fluid gets topped off while it's still on the rack. Don't worry.
BUT --- you unfairly stated that it cost that amount for a rebuilt transmission and that's not totally true.
You had a lot of other things done --- and I'm not totally sure you haven't had some other part fail - do you still have control of the vehicle?
Is the fluid black or shades of that? Things can happen and a good shop will want to get back into the unit to see what happens.
This could be a fault of the installer and not the builder ... so there's that too.
There's too little information in your post to form a good opinion.
Yes true,
In my case the installer messed up putting one of the coller fittings on the steel-braided hose (a common mistake if yhou arent careful) and thus tranny fluid leaked all over the underside od my truck. Losing 2-3 quarts was enough to burn up the 2/4 gear belt (or so it is thought). The installer of course denies responsibility, even after I paid to run those lines too.......so chalk it up to lesson learned.
before someone asks:
I had steel braided line run because it was to a Derail dual-fan transmission cooler mounted inthe right brake duct. The stock radiator was replaced with an FSR dedicated coolant radiator (no Trans fluid)
In retrospect I wish I had used thr stock cooling lines and simply tapped them at the front cross member rather than running new lines all the way to the transmission.
Yes true,
In my case the installer messed up putting one of the coller fittings on the steel-braided hose (a common mistake if yhou arent careful) and thus tranny fluid leaked all over the underside od my truck. Losing 2-3 quarts was enough to burn up the 2/4 BAND (or so it is thought). The installer of course denies responsibility, even after I paid to run those lines too.......so chalk it up to lesson learned.
Fixed it for ya.
TrailblazerSS 3SS
Lot of pump failures are result of over or under converter to flex plate spacing.
Discussion Starter · #14 ·
To keep you guys posted cuz I love this site and opinions. Blew again Took it back to put in a brand new transfer case because this blew. Now I have a new rebuilt tranny with Corvette servos billet shafts new differentials. And more picking it up this weekend I will post my inventory on the bill soon to follow.
1 - 14 of 14 Posts
