1 - 20 of 25 Posts
TBSS 3SS
I started the install the last week of December but I couldn't finish since I didn't have the right connector that goes to the stock purple connector. Lucky thing I have another car to drive. I did not want to reinstall the stock clutch fan...too lazy.
I have to give KUDOS to Kelly of PCMforless for her outstanding service. The customer service she had provided was outstanding. A message to Alvin, she is a keeper.
The parts were used but took the chance.
Parts list:
1 - C6 Fan
1 - PCMforless bracket and connectors
1 - Fan Patch courtesy of PCMforless
Install:
The fan brackets were cut and modified with aluminum brackets. So the PCMforless brackets were not needed. If someone needs it, make me a reasonable offer. Fan bolted to the top two holes with stock bolts and the bottom two with the used parts sent to me. I was also missing the jumper so I had to wait for a Christmas present from Kelly. Thanks again. :biggrin2:
I soldered, 3m electrical coated then shrink tube all cut wires.
I believe the fans are set to turn off 5 secs after engine shutoff. I like that. The settings are also set for a delay turn on of 5 secs. I modified PCMforless fan patch settings to compensate for a start up delay to minimize the amp draw.
It is amazing how much room there is now to work on the belts. Our TBSS should have come with E-Fans....why GM?
Performance:
From the seat of pants dyno, it drives with more spunk. Quicker to accelerate from 0. I can now chirp the tires when I smash the go-fast pedal.
Drove it in Honolulu traffic after the install and the temp reading on my aeroforce read anywhere between 188 to 195F. Never got above 200.
Current Mods:
BBA Tune
160 t-stat
Prada Spec-X tires
Corvette Servos
Jetttstream Stage 3 Intake
E3 Spark Plugs
Taylor Spark Plug Wires
C6 e-Fan
Transmission Cooler - front mount
Now for the pictures....:biggrin2:
Passenger Side View:
Driver Side View:
Drinking again....whew. Thank God and Kelly for all their help.
Rotopros install tomorrow. Custom paint job. :cheers1:
TBSS 3SS
Discussion Starter #2
I need to figure out how to route the wire and where to install the switch.
im glad your happy with the efans because they were one of my favorite mods(even though they shoulda came factory as because it doesnt affect towing) I gained another +1.5 mpg and what seems about 10 whp for like 200 bucks..
however, many on here have had issues with the c6 fan or the ls1 efans with charging issues etc...
2006 TBSS (LT Based)
Hey Bro, I'm really glad it all worked out for you.
Thank ive seen someone take the headlight switch apart and put a on/off button like theat above the fog button... Thats my plans when I go with a manual switch.
Parts list:
1 - C6 Fan
Install:
Performance:
Current Mods:
BBA Tune
160 t-stat
Prada Spec-X tires
Corvette Servos
E3 Spark Plugs
C6 e-Fan
Driver Side View:
Does the foam wrap prove effective in dispensing heat from the intake tube there?
moar cowbell
Trailblazer
Thank ive seen someone take the headlight switch apart and put a on/off button like there above the fog button... Thats my plans when I go with a manual switch.
yep, good place. thats where my tranny cooler fan switch is
2007 TrailBlazer SS
Here's where you can mount the switch:
The headlight switch comes apart carefully. The wire harness I routed through the steering column boot at the firewall.
or below the fog button...lol :coolthumb:
TBSS 3SS
Thanks Scjzman. I'm happy how it turned out. I'll update your rating.
Yes. I got that idea from another member. Forgot his name but he is from Arizona where its much hotter than Hawaii....and more guns. :doh:
TBSS 3SS
Focking awesome place. Just didn't know it if it would fit. Thanks for the suggestion.
Thank you for the pictures. I was thinking on top of the fog switch but I think it looks better on the bottom. That is a clean install, looks factory install.
07 TrailblazerSS Imp
This was my idea for aux for trans cooler and future install that I did last fall.
I have the C6 fans as well, except i dont have a switch. how hard would it be to wire up a switch to my existing C6 fans?
Yours looks great! nice job!
TBSS 3SS
Discussion Starter #15
If you see the two middle connectors, it goes in line between the C6 fan and the harness that powers it. Running the wires will take some time as another posted to run it through the steering column hole.
I believe the time is taken up by keeping it clean looking by using wire loom and trimming all the tie wrap ends.
Do you have to take off the dash or does the fog light plate come off by itself?
You can remove the pannel off the side of dash and unplug wires. Push in on some tabs to release switch and pull it out
TBSS 3SS
Discussion Starter #17
Thanks Aaron. A PITA to take off the dash trim...why did GM use so many screws and layered the dash since you have to take off the bottom panel to get to the screws for the the dash trim.
:doh:
Another weekend job to install the variable switch...need to buy another case of beer.
:cheers1:
TBSS 3SS
Discussion Starter #18
Positive feedback on the C6 fan. I heard others were having problems but I drove in stop and go traffic today -going and coming- and my temps never got above 195F. Running temps are at 186-191F.
Today was an over cast day but considering this is in Honolulu temperature; 75 degrees, 57% humidity.
=ЯΛWSSUM=
Im in need of the efan set up... how much did it run you and was it a pain to do yourself.. run into any probs?
I never use anything other than the middle/ECU preferred speed. A few times in stop and go 90 degree heat I used the high speed or if I need the engine to cool for a romp. I actually have never use the low speed, does anyone?
1 - 20 of 25 Posts
