Yeah, well I have two different belts. One for use with the UP Crank pulley by itself and one for use with the Alt pulley. So far I have not needed the Crank pulley, so I might try to sell it and the belt together
Yeah, got ahead of myself there...fixed nowDid you mean "alt" pulley? :biggrin2:
Actually, the gates K040335 is too long. Mine kept coming off. I went with a gatorback K040332 and it's better, but I believe the gate K040330 is going to be the right one. The problem on mine is the tensioner was all the way down on the 335 belt and not putting any tension on it. The 332 gets a little tension, but it comes off about 1-2 times a month. So i will be trying the 330 to see if it fits.OK, heres the deal....
* U/D crank pulley - This small belt is used no mater what. Gates # K040335
( 4 Ribs 9/16" x 34" )
http://www.rockauto.com/dbphp/prt,64,K040335
* I have the "smaller" pulley for the altenator, however it has NOT been installed. I am currently using the belt for the "smaller" pulley without any problems on the stock alt pulley with: Gates # K060888
( 6 Ribs 13/16" x 89 1/2" )
Hope this helps.
Thats weird, never had a prob with the K040335, put it on the first time and has never been off.Actually, the gates K040335 is too long. Mine kept coming off. I went with a gatorback K040332 and it's better, but I believe the gate K040330 is going to be the right one. The problem on mine is the tensioner was all the way down on the 335 belt and not putting any tension on it. The 332 gets a little tension, but it comes off about 1-2 times a month. So i will be trying the 330 to see if it fits.
Put your zip code in and find the nearest shop:well guys where can i buy the fucken tool to take the original pulley off...apparently no one has done one of this before in my area and say they cant do shit !!!!what should i do !?
