If you stuck with the oem sized band I probably wouldn't argue with you there. But if you change to the wide band, that's a no no. I hear you can put them on a lathe though and some shops will do that. But there isn't a stated minimum thickness spec I can find otherwise.I just check the drum with a straight edge. If it's flat, it's flat.
