1 - 20 of 41 Posts
Administrator
i just want a flex plate that someones used with a yank ptb converter. I dont want any bolt issues or any of that bs.
What flex plate are you guys using??? what bolts?? shim kit??
06 3SS
Dang Chris I didn't see that on your website! Give us a run down of the specs between yours and OEM. Weight, thickness, etc. Also, will this fall under your coveted "We dare you to break it" slogan? :muahaha:
Lighter is better
if it is strong enough to hold. Thicker is better for strength. Pick the lightest that you can use for your application!
The Worlds my Playground
Totally agree, however the less the rotational Mass, the quicker it will rev and respond.
It's an SUV.. You want more rotating mass to get the brick off the line..
The heavy models smooth out engine idle with big cams, and offer harder launches and more rpms during the gear shifts. The light weight flywheel models allow for faster turbo spool up and improved engine acceleration, and deceleration for street, circle track and road race applications.
2008 Imperial Blue
Come on, really. I am totally in agreement with the manual flywheels and weight, but the flex plate weight difference is not that significant when you compare it to a converter that has a clutch.
Maybe an 8"-9" converter without a clutch, but these things with clutches weigh a ton by themselves, relatively speaking.
Also, the heavier flywheels (manuals) help dampen the power pulses when you run big cams and trying to get a streetable idle.
:2cents:
Rotating mass is just that, you still have to consume more power to turn more weight...period. Not one person can argue this, and that was my point. I agree a heavier setup will help dampen things, however, as you've said, the convertors are heavy enough, so they can help keep things spinning, I'll save as much weight off the flexplate as I can to lighten/or keep it, the assembly as light as possibble personally. You guys probably think adding a couple pounds to each wheel is not big deal too huh.
And TrailLaser,make sure to leave your lifejacket on the boat please, other people might need to use that.
06 3SS
My turn! When you get to a power level that'll require you to go to a plate as strong as Circle Ds there aren't enough place holders after the decimal at any racetrack that'll be able to measure the difference that extra 1.3 lbs made.
1 - 20 of 41 Posts
