1 - 12 of 12 Posts
America!
Corvette C6
Thinking about adding the sonnax servos, I have a stock trans with 43k on it. Can i add these with out a problem or ?
Sure you can I did the vette servo from circle D made it shift firmer.
America!
Corvette C6
The Sonnax Servos are a great choice over the corvette Servo and you should have no issues or problems.. check out these links and Part Summary for more info to help with your decision.
2nd Gear "Super Hold" Servo
http://www.sonnax.com/product-lines/high-performance-transmission/parts/2012
4th Gear "Super Hold" Dual Servo
http://www.sonnax.com/product-lines/high-performance-transmission/parts/2010
EDIT: nvm i see you gotta do 2 of them for 2nd and 4th
Who can i get them from
Just do the vette servo for now and when you build the tranny then do the sonnax servos.:2cents:
America!
Corvette C6
i guess once i figure wat price difference is go from there. is the sonnax gonna be rougher on the trans causing a higher rate of failure?
06 TrailblazerSS AWD
I am going to switch out my vett servo to sannox in feb so after that i can give you some info on the differance.
i guess once i figure what price difference is go from there. is the sonnax gonna be rougher on the trans causing a higher rate of failure?
Remember you always get what you pay for with aftermarket parts. People commonly mistake the design flaws of the fairbanks servo to the sonnax just because they are both made of "billet". However, they could not be more wrong.
Sonnax's product line is all about taking the operation of the transmission and enhancing the operations to make it work better and last longer. Combine that with correct programming and your transmission has a better service life. Obvious abuse and mistreatment can still cause failures though
Hope this helps..
Give fms (262) a call he has a shift kit with the sannox servos,that is what he is going to put in my SS.
1 - 12 of 12 Posts
