1 - 5 of 5 Posts
I just bought a rear addco from a member and I'm trying to figure out if I can use my stock bushings or if I need a bigger bushing? I plan on finding some 1- 1/8" collars to slap on there with the install as well.
07,09 -3SS- Blk,Slv
Call Addco to order the replacement bushing at 800-338-7015.
Part #804 - $6.48 per set
They are poly and larger than the stock bushings, but fit in the factory mount.
I was told that i could use the rear stock sway arm bushingS? Anyone know for a fact? I ordered the addco bushings just wanting to slap this sway bar on while the weather permits.
07,09 -3SS- Blk,Slv
You can, they will be tight. Originally Addco was shipping a set of bored out stock GM rubber bushings with the bars. The poly bushings they came out with later are a better choice, IMHO.
1 - 5 of 5 Posts
