1 - 20 of 21 Posts
07 TrailblazerSS Imp
I just found a nice place to add a coouple switches-one for the Trans cooler fan and another for future use.... might as well do both now while its out. I put them in the lights control module and its easy to pop out. Its almost inconspicuous.
and I added this one for my air horns
Nice clean install.
Question: Do you have a Gauge to get a Temp reading on your Trans???
And if so, wouldnt you want the Trans Cooler on all the time???
:yay2::yay2::yay2:
Look good! I picked up the same switches for my tb, I was thinking of putting them in the center console, but that looks nice and clear there too.
Nice clean install.
:yay2::yay2::yay2:
No, you wouldn't want your trans cooler on all the time. You want the trans temp to be right around 175*F since this is where trans fluid is designed to operate.
Ok, but is there a gauge or reading on the DIC to tell you the temp? Or must you have an aftermarket gauge to obtain this reading?:yay2::yay2::yay2:
You'll need a Dashawk or an Aerforce gauge to be pratical to see it direct from the PCM or install your own temp sensor and mechanical gauge. . You can simply get a obd scanner and look at the trans temp that way.
TrailBlazer SS AWD
I Like It. I Never Would Have Thought Of Putting Anything There.
For My N2O Switches I Took Out The Homelink Garage Door Opener Buttons, Bought A Blank Overhead Consol On eBay And Drilled It Out. Here It Is.
That's what I did, one for the trans cooler fan and the other for the efans.
TBSS
That is sick!! imagine opening the door to a tbss and seeing that!
Nice work brother
Discussion Starter #19
Nice clean install.
:yay2::yay2::yay2:
I have an Aeroforce which is set to instant MPG and the trans temp.
Discussion Starter #20
bump for the first post- edited to show a second pic of the momentary switch I installed on the console arm rest for my airhorn.
1 - 20 of 21 Posts
