1 - 12 of 12 Posts
would walk out to garage and would hear ac blowing full blast even though truck not running and keys in house. also sometimes driving down road would go to full blast for like 30 seconds then back to normal. any body else have this issue or know whats wrong
WANNABE SS OWNER
Trailblazer SS 2wd
That's a new one to me:dunno: Do you have electric fans installed?
TrailblazerSS 3SS
Probably a resistor pn 89019088, same thing happend to mine the day I bought it
You may want to replace the pigtail too pn 15862656
come to find out that the dealership installed new program for blower motor to blow to dry up water left in evap. because i was complaining about smell from ducts. TSB # 99-01-39-004C
2006 white 2wd
my friend's 06 blows air when the truck is off and no keys, I thought it was to cool off the inside of the truck.
2006 white 2wd
yeah got tsb on mitchell but wont let me copy paste
#99-01-39-004C: Air Conditioning Odor (Install Evaporator Core Dryer Kit and Apply Cooling Coil Coating) - (Jun 12, 2009)
Subject: Air Conditioning Odor (Install Evaporator Core Dryer Kit and Apply Cooling Coil Coating)
Models: 1993-2010 GM Passenger Cars and Trucks (Including Saturn)
2010 and Prior HUMMER H2, H3
All Equipped with Air Conditioning
This bulletin is being revised to add the 2009 and 2010 model years. Please discard Corporate Bulletin Number 99-01-39-004B (Section 01 -- HVAC).
Condition
Some customers may comment about musty odors emitted from the Heating, Ventilation and Air Conditioning (HVAC) system at vehicle start-up in hot, humid conditions.
Cause
This condition may be caused by condensate build-up on the evaporator core, which does not evaporate by itself in high humidity conditions. The odor may be the result of microbial growth on the evaporator core. When the blower motor fan is turned on, the microbial growth may release an unpleasant musty odor into the passenger compartment.
There are several other possible sources of a musty odor in a vehicle. A common source is a water leak into the interior of the vehicle or foreign material in the HVAC air distribution system. Follow the procedures in SI for identifying and correcting water leaks and air inlet inspection.
The procedure contained in this bulletin is only applicable if the odor source has been determined to be microbial growth on the evaporator core inside the HVAC module.
Correction
Many vehicles currently incorporate an afterblow function within the HVAC control module software. The afterblow feature, when enabled, employs the HVAC blower fan to dry the evaporator after vehicle shut down and this function will inhibit microbial growth. Technicians are to confirm that the customer concern is evaporator core odor and that the vehicle has the imbedded afterblow feature, as defined in the SI document for that specific vehicle model, model year and specific HVAC option. Refer to SI for enabling the afterblow function. Vehicles being delivered in areas prone to high humidity conditions may benefit from having the afterblow enabled calibration installed prior to any customer comment.
Important: If the vehicle is not factory equipped with the imbedded afterblow enable feature, it may be added with the Electronic Evaporator Dryer Module Kit (P/N 12497910 or AC Delco 15-5876).
Important: When installing the Electronic Evaporator Dryer Module, you MUST use the included electrical splice connectors to ensure a proper splice. Complete detailed installation instructions and self testing procedures are supplied with the kit. If necessary, the Electronic Evaporator Dryer Module may be installed underhood if it is protected from extreme heat and water splash areas.
To immediately remove the evaporator core odor on all suspect vehicles, it is necessary to eliminate the microbial growth and prevent its re-occurrence. To accomplish this, perform the following procedure:
Vehicle and Applicator Tool Preparation
1. The evaporator core must be dry . This may be accomplished by disabling the compressor and running the blower fan on the recirc heat setting for an extended period of time.
Note: Compressor engagement will cause the evaporator core to remain wet and will prevent full adherence of the Coiling Coil Coating to the evaporator core surfaces.
2. Verify that the air conditioning drain hose is not clogged and place a drain pan beneath the vehicle.
3. Place a protective cover over the carpet below the evaporator core.
4. Remove the cabin air filter, if equipped, and cover the opening prior to applying the Cooling Coil Coating, as the product may clog the filter. If the cabin air filter appears to have little or no remaining life, suggest a replacement to your customer.
5. If the HVAC module has a blower motor cooling tube, be careful NOT TO SPRAY THE COOLING COIL COATING INTO THE BLOWER MOTOR COOLING TUBE .
6. Attach the Flexible Applicator Pressure Spray Tool (J-43810-20A) to a compressed air line operating at 586 kPa (85 psi) to 793 kPa (115 psi).
7. Shake the bottle of Cooling Coil Coating well. Screw the bottle onto the cap on the applicator tool's pick-up tube.
Note: The pick-up tube is designed for 120 ml (4 oz) and 240 ml (8 oz) bottles and should coil slightly in the bottom of a 120 ml (4 oz) bottle.
8. Use one of the following three methods to apply the Cooling Coil Coating.
Important: If the Pressure Applicator Spray Tool (J-43810-20A) is not available, the Cooling Coil Coating is also available in an aerosol can (P/N 12377951 (in Canada, 10953503)).
Application Through Blower Motor Control Module Opening
• Remove the blower motor control module (blower motor resistor). Refer to the applicable procedure in SI.
• Clean any debris or foreign material from inside the HVAC module and on the evaporator core surface.
• Apply the Cooling Coil Coating directly to the evaporator core through the blower motor blower motor control module (blower motor resistor) opening.
• Use the flexible wand to direct the Cooling Coil Coating over the entire evaporator core and surrounding gasket surfaces.
• When the application is complete, install the blower motor blower motor control module (blower motor control module).
Application Through Blower Motor Opening
• Remove the blower motor. Refer to the applicable blower motor removal procedure in SI.
• Apply the Cooling Coil Coating directly to the evaporator core through the blower motor opening.
• When the application is complete, install the blower motor.
Application Through a Hole in the HVAC Module
• If neither of the two previous application methods are available, it may be necessary to drill a hole in the HVAC module.
• Locate an area of the HVAC module between the blower motor and the evaporator core. Drill a 10 mm (3/8 in) hole in the HVAC module. Use caution to keep the drill clear of the evaporator core and the blower motor fan.
• With the air distribution vents closed and the blower motor fan speed on HIGH, insert the applicator tool into the hole and spray the Cooling Coil Coating into the airstream toward the evaporator core.
• Use a GM approved RTV sealant to plug the hole in the HVAC module.
9. After the Cooling Coil Coating application is complete, start and run the vehicle for approximately 10 minutes, with the compressor disabled, HVAC mode set to Recirculate/Max, heat set to full warm, blower motor fan speed on high, and one window open approximately 12 mm (1/2 in). This cures the Cooling Coil Coating onto the evaporator core surface.
10. While the engine is running, rinse the applicator tool with warm water to prolong the life of the tool. Be sure to spray warm water through the nozzle to rinse out any residual Cooling Coil Coating still in the capillary pick up tube, otherwise it will dry and clog the applicator tool. Also remove the small green valve from the bottle cap and rinse it thoroughly while rolling it between two fingers and then reinstall it. If this valve is clogged , the Cooling Coil Coating will not flow through the applicator tool.
11. Shut off the engine and enable the compressor again.
12. Verify proper HVAC system operation.
13. Remove the protective cover from inside the vehicle.
14. Remove the drain pan from underneath the vehicle.
15. Reinstall the cabin air filter if necessary.
Parts Information
Important: The Cooling Coil Coating listed below is the only GM approved product for use under warranty as an evaporator core disinfectant and for the long term control of evaporator core microbial growth.
Part Description
GM Part Number
SPX Kent-Moore Part Number
Cooling Coil Coating (CCC) Kit (with flexible applicator tool and 1 bottle of Cooling Coil Coating)
12346391
J-43810-A
Cooling Coil Coating Flexible Applicator Tool only
N/A
J-43810-20A
Refill for Cooling Coil Coating Applicator Kit (2 x 120 ml (4 oz) Bottles of CCC)
12346390
(N/A in Canada, use SPX Kent-Moore J-43810-4)
J-43810-4
Refill for Cooling Coil Coating Applicator Kit (1 x 120 ml (4 oz) Bottle of CCC)
N/A
J-43810-30
Cooling Coil Coating (1 x 180 ml (6 oz) Aerosol Can of CCC)
12377951 (In Canada use 10953503)
N/A
Electronic Evaporator Dryer Module Kit (one per vehicle)
12497910 (AC Delco 15-5876)
N/A
Warranty Information
For vehicles repaired under warranty, use:
Labor Operation
Description
Labor Time
D3316*
Apply Cooling Coil Coating and Install Electronic Evaporator Dryer Kit
0.8 hr
*This is a unique labor operation for bulletin use only. It will not be published in the Labor Time Guide.
2006 TBSS (LT Based)
Mine has been that way for two years.
1 - 12 of 12 Posts
