1 - 2 of 2 Posts
· Registered
My 08 tbss has a weak airflow in the front vents like it’ll blow very little on a ac high level while my rear vents will work just great . What can be the problem and solution to fix my airflow to match the ac level ?
· Lighter-than-you
one of your vent blend door actuator isnt working or your front blower fan is on its way out. hopefully your fan is just going out as its cake to replace.. blend door actuators are a bitch just to find out which actuator it is, then you have to rip dash out to get to it to replace it. Best of luck!
1 - 2 of 2 Posts
