1 - 8 of 8 Posts
08TbSS - Black
I've been having problems with my AC for a while now -- first it was the AC control module, then when I finally got that sorted out, the system was pretty much out of freon. Guys at the shop recharged it and added dye. 3 weeks later, it's struggling to keep up with the Florida heat.
Back to the shop to find the leak -- get a call 10 minutes ago that there's a hole in the AC condenser and that I'm looking at just over $1000 to fix it.
Holy %$#@#!!!!
I've never worked on AC before -- first, is this a crazy quote to replace an AC condenser? Was told it's 4.5 hrs of labor. Damned expensive. second -- anyone have any pointers on replacing this myself? Like I said, I'm a noob on AC issues, but I can twirl a wrench as well as the next guy.
Any help is really appreciated!
Reed
i had mine replaced a few months ago for $770! the parts total was $460 and the rest was labor! it took my mechanic 4.2 hours, and he said it was a bitch to do!
Reactions: BlackJax
You have a crap load of stuff in the dash area to change it, its a royal PITA. If you havent done one, leave it to the pro's, cause if theres a leak and you have to re-charge, its thier fault!! :) Plus you get a warranty. Have the change the orifice tube while they are at it, and put in the one that helps control temps at idle. They have a special high efficiency one they can order for most vehicles (assuming they have for our SS too).
G/L
Reactions: BlackJax
08TbSS - Black
Thanks for the info guys -- much appreciated!
Walter, some really good points here - especially about having the work covered by the shop in case it's not right. If I do this DIY, I'm sure to pay some level of stupid tax just because it'll be my first time thru this. But one thing...
The AC condenser is in front of the radiator (right?). I haven't really researched this, but I hadn't thought that I'd need to mess with the dash area at all. What did you need to do behind the dash?
Thanks! :cheers1:
I read too fast, for some reason I had evap core on the brain..... LOL
Hell if its the condenser, you can do it yourself. Its an easy fix. Just make sure to buy new metal/rubber orings from GM. Dont re-use. And if you fill yourself, 24oz = two cans = full! :) Just buy the cheapy fill kit from Advance/Autozone. You should get 37-39 degrees, thats what I got with 24oz. Factory calls for 23oz I think. I end doing all mine by pressure, and not ounces. I ended up with close to 30oz to get to 35psi at idle on the low side, and it blows 35-36 all day long on a low 90 degree day. Remember each car is differant, compressor age, orrifice tube condition etc. So dont just throw 30oz in yours, start with 24.
08TbSS - Black
Man, I'm with you there! Garage quoted 4.5 hrs labor for this job - that's probably a little high, but even at say 3 hrs work there ain't no way I'm dropping in a used part.
With this Florida heat we have, I want this one fixed right, you know? :cheers1:
1 - 8 of 8 Posts
