1 - 4 of 4 Posts
XPTBSS
Well I searched and searched and couldn't find much about this issue so I figured I would post it. I have been having a/c issues and abs light/stabilitrak issues for a few weeks now since I got my 80E swap finished. Well low and behold its another Ignition Switch related issue. Pulled the ignition switch out and took off the back piece. Started the truck with the ignition switch. Pressed down on one of the prongs and everything was functioning. BAD CONTACT = voltage issues to these systems. Headed down to Orielly to pick up another warrantied switch (gotta love life time warranty) came home and 10 second later popped the new switch in and everything is good to go.
So if you have these symptoms
-ABS light on
-Stabilitrak light on
-No A/C
Swap the ignition switch.
I dont have an ABS light or Stabilitrak light but my ac keeps acting up again. It comes and goes. When it blows cold it is freezing but then its like it fades then back to hot air. This anything to do with ignition switch
1 - 4 of 4 Posts
