1 - 7 of 7 Posts
1- I need the trans
2- need the conversion kit Frm Joe
What eles to I needs shift linkage,drive shaft any thing eles I need please help ???
XPTBSS
You will also need your shift linkage from the 70E, the neutral safety switch from the 70E and a new converter. If you get your converter built with a 70E front than you can reuse ur old flex plate.
You will need the below items
4L80E Flexplate (Depending on Converter)
4L80E Shifter Cable Bracket
4L80E Lower Bellhousing Cover
4L80E Slip Yoke
4L80E Dipstick and Tube
Where do I get this stuff an will a stock 4l80 converter,flexplate,lower bellhousing,slip yoke, work of I go to lik a salvage yard or no......o an do I need a different drive shaft or no
Where would u get a converter wit a 70e front???
1 - 7 of 7 Posts
