1 - 12 of 12 Posts
Hello,
I searched the forums, found very little on the subject. Hope someone can help me out please. 2006 TBSS with a really nasty smell coming from the AC vents when AC is first turned on. It is mold, I believe....does anyone know how to get rid of it? I already sprayed Lysol into the vents and cowl area outside the car....also tried professional grade cleaners that I ran down the vents with a small hose....it gets better for about a day then the smell comes right back. I believe the mold lives on the evaporator....do I have to tear the whole dash apart to get rid of this problem? Does anyone have any suggestions or instructions for the Evaporator removal and what to do once I get to the Evaporator? Last thing i want to do is get there and not be able to solve the problem...this forums rocks....Thank you in advance for any help you can offer me....
2006 TrailblazerSS
Your AC drain may be plugged
if you haven't checked that, pop the hood and follow the AC lines to the firewall.
There is a rubber fitting to the right of the lines. It should be dripping with the engine running and AC on.
If it's not, remove it and stick a shop vac over the hole. This should suck most of the ugly out of the box.
Clean the rubber fitting up and jam it back on there.....Bam you're done.
MiST? In Vehicle Air Quality | UView
Find a shop that has this type of service. I have this at my shop. It works great. I use it once a year in my personal vehicles. It can help with cars that have been smoked in also.
I see you're in South Florida....I'm in Miami. Do you have a shop or know a shop that can do this for me? The smell is horrible and I'm considering changing the evaporator....that's how bad it is.
Thanks
Maybe it was a clogged cabin filter the whole time.
1 - 12 of 12 Posts
